Tagged: aim tutorial, discovery-aim, Electromagentics, fluids, structures
September 26, 2022 at 10:00 am
Solution
ParticipantThese tutorials are taken from Cornell University’s ANSYS AIM Learning Modules
In this short course you will be taken through ANSYS Discovery AIM and learn how to solve a variety of problems. The learning modules lead the user through the steps involved in solving a selected problem or set of problems. They not only provide the solution steps but also the rationale behind them. It is worthwhile for you to understand the underlying concepts as you travel through the learning modules in order to be able to correctly apply ANSYS Discovery AIM to other situations that you may encounter.
Static Structural Analysis
3D Finite-Element Analysis of a Bike Crank
Analysis of cantilever beam with I cross-section
3D Analysis of Combined Loading in a Signpost
Structural Analysis of Plate with Hole
Stepped Shaft in Axial Tension
Modal Analysis
Cantilever Beam Modal Analysis
Fluid Flow Analysis
3D Convection through an Electronics Box
Fluid Flow Through a Transition Duct
Compressible Flow Through A Nozzle
Compressible Flow Over an Airfoil
Taylor-Couette Flow between Rotating Cylinders
Flow through an Aortic Aneurysm
Compressible Flow over a Wing-Body Junction
Thermal Analysis
Heat Conduction in a Hollow Cylinder
Electromagnetics Analysis
Permanent Magnetic Circuit with Air Gap
- Discovery Live: How to change units
- Discovery AIM tutorial – Analysis of cantilever beam with I cross-section
- Discovery AIM – Scaling deformation contour results
- Discovery AIM tutorial – 3D Finite-Element Analysis of a Bike Crank
- Discovery AIM tutorial – Structural Analysis of Plate with Hole
- FAQ: Missing Areas of the User Interface in Discovery Live
- Discovery SpaceClaim: Getting Started Tutorials
- How to setup a Parameter Study
- Creating a Helical Geometry in SpaceClaim
- Convert 2D Drawings to 3D Models in Minutes with SpaceClaim
