Fender force
    • r.abbasi
      Hello
       have defined two fenders in these positions. Although the animation shows that the second fender is working (the bottom), there is no force detected. Could you please provide guidance regarding this issue?
    • r.abbasi
      the compression (fender motions) shows that its zero! but animation is in compression
    • Ashish Khemka
      Can you share the setup you are using - the contacts, loads and boundary conditions? At which location are you expecting compression and force?
      Ashish Khemka
