December 2, 2024 at 8:30 amuygar.kartalSubscriber
Hello guys,
Currently, I am running a thermal analysis in Ansys Discovery, and I want to place a sensor at the center of a sphere to view its time-dependent temperature graph. Is there a way to do that?
I would appreciate it if you could help. -
December 2, 2024 at 11:13 amSubashni RavichandranForum Moderator
You can create a point at the center of the Sphere and create a custom monitor at the point location.
To create the point, you can use the 3D point tool under Design Tab > Create,
Check out the below Knowledge article for tips on creating monitors.
Discovery Quick Tip- Monitors on Construction Geometry | Ansys Knowledge
December 2, 2024 at 2:33 pmuygar.kartalSubscriber
Thank you so much for your help that was all I need. 😀
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
543
523
225
209
