TAGGED: 3d-model, Ansys Discovery, field-distribution, temperature
August 13, 2024 at 1:04 pmthomason-sanchezSubscriber
In my simulation I do not manage to have the temperature's distribution in Refine mode. If I put an inlet flow at 40°C in Refine Mode , my entire fluid domain will be at 40°C but If I run the same simulation in Explorer Mode I have a temperature's distribution. Why ?
Thanks in advance
SANCHEZ Thomas
August 20, 2024 at 8:31 amDevendra BadgujarForum Moderator
Hello Sanchez,
Can you please confirm if you are using LiveGX or Fluent Solver for this? Which version of Ansys Discovery you are using?
Devendra
August 21, 2024 at 9:56 amthomason-sanchezSubscriber
I was using the default one on the 2022 R1 so it must be the LiveGx solver because there is no button to switch solver in the simulation option tab.
Regards
Thomas Sanchez
September 2, 2024 at 6:29 amDevendra BadgujarForum Moderator
Hello Thomas,
LiveGX solver is available from Discovery 2023 R1 onwards, you should be using the Refine Fluent solver. Can you share an image of your setup to understand this better?
Devendra
September 3, 2024 at 11:38 am
September 3, 2024 at 11:47 amDevendra BadgujarForum Moderator
Hello Thomas,
Can you reproduce this issue with any other sample models available and let me know? If that is also showing the same than it has to do something with your drivers.
I would recommend please try updating your graphics drivers from manufacturers website e.g Nvidia.
Devendra
September 4, 2024 at 11:36 amthomason-sanchezSubscriber
My graphics drivers are up to date and I tried with others sample I have the same problem.
Thomas
October 5, 2024 at 3:01 pmDevendra BadgujarForum Moderator
Sorry for the delay. Did you try this in the latest version of Ansys Discovery 2024 R2?
If its the same, can you try steps from this Discovery Refine: Results fail to appear after solve in Refine stage. - Ansys Knowledge.
Devendra
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- Crash by using Script Editor
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Temperature’s Distribution not available in Refine Mode ?
- Overlapping contact face
- Thermoelectric Cooler Model
1161
488
487
225
201
