August 20, 2024 at 6:40 pm
Fabian Scr
SubscriberHave anyone the same problem the Spaceclaim crash by using Script Editor? Or have anyone a Fix? -
August 21, 2024 at 1:47 pm
Devendra Badgujar
Forum ModeratorHello Fabian,Â
Do you face this issue with any specific model or even with simple model created in SpaceClaim?Â
It could be beneficial to reset the user settings from SpaceClaim Options > Advanced > Reset All User Settings.
The main thing we recommend in this type of situation is to make sure the drivers for the graphics card are up to date. Â
Make sure to go directly to the card manufacturer's website to check for the latest version.Regards,
Devendra
August 21, 2024 at 5:27 pm
Fabian Scr
SubscriberIts every (by Start Click (no Model) or with Simple Model
I Have Reset All user Settings and the Driver is Up to date :-(Â
August 22, 2024 at 1:38 am
mjmiddle
Ansys EmployeeDoes it crash when you open the script editor or when running your script? Your script may do something invalid with the current model.
You can also try running in "run" mode. The debug mode runs in a different thread, allowing you to click in the model window while it runs and possibly confusing the script. Click the pulldown by the right-pointing triangle at the upper right of the script editor, and choose "Run." Then use that same green triangle to run the script:
August 24, 2024 at 7:28 pm
Fabian Scr
SubscriberÂ
Crash by Click the Button Script Editor or the Button Block i can not Open the Editor
August 25, 2024 at 11:12 am
mjmiddle
Ansys EmployeeSounds like running on some unsupported configuration. Maybe the operating system build or remote display software.Â
August 31, 2024 at 12:10 pm
Fabian Scr
SubscriberIs the Newest Build from Windows 11, the Newest Driver from Nvidia and have No Remote Display Installed
September 4, 2024 at 1:42 pm
mjmiddle
Ansys EmployeeCheck against tested graphics cards for 2024 R2:
https://www.ansys.com/content/dam/it-solutions/platform-support/2024-r2/ansys-2024-r2-graphical-display-graphics-cards-tested.pdf
Also, try deleting or renaming these while SpaceClaim is closed to return to default settings:
%APPDATA%\Ansys\v{version}
%APPDATA%\SpaceClaim
%APPDATA%\..\Local\SpaceClaimIf you can't figure it out, try reinstalling.
October 2, 2024 at 8:32 pm
Fabian Scr
Subscriberi have now try delete all Spaceclaim and Ansys Folder
And Reinstall de Spaceclaim 2024 R1 and Try the Older SpaceClaim 2023 R1 and is the same Result!
Spaceclaim 2023 and Spaceclaim 2024 Crash by Klick the Script or Block Recording
5589
1885
1403
1298
