TAGGED: Ansys Discovery, ansys-design-modeler, enclosure, fluent, object
December 21, 2024 at 2:59 pmdeimicSubscriber
Greetings,
I have downloaded a cow 3d model and I am trying to create an analysis for it in Fluent. However, when I try to generate the enclosure via Design Modeller, I get an error, regarding to the body. Also, I noticed that the model is now transparent somehow. I tried stiching is Discovery, but the feedback I get is that there are no faces to stich. The files are .obj and .igs, same situation for both of those. Please note that I am relatively new to this software. Any help would be very appreciated :)
Viewing 0 reply threads
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
