September 17, 2024 at 6:44 am
Sijal
SubscriberI am facing very strange issue in Spaceclaim.I cannot move or pull any geometry beyond 500 meters in any direction.I know spaceclaim do not have limits. I have worked on all versions and all of sudden I getting same issue on spaceclaim 2022, 2023 and 2024.Any idea?Just for the context,1. in Design modeller we enable large model support to draw very large domains etc. But this is not the case with spaceclaim.2. I am using spaceclaim for more than 5 years and never faces issue.3. Even last week I have created wind turbine domain with size of 632 m, 756 m and 1260 meters in upstream, diameters and downstream. Now I am trying to create same and not able to do it.4. Even I cannot move any face beyod 500 meters. -
September 17, 2024 at 9:04 am
Forum ModeratorWhat units are you using for length? I've just checked on 2024R2 and pulling a surface 600m (as opposed to 600,000mm) worked fine.
Ansys Innovation Space
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- ansys fluent error when opening it “unexpected license problem”
- access to path files denied error
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- Unable to connect to the license
- Tutorial or Help for 2 way FSI
- Questions and recommendations: Septum Horn Antenna
- Moment Reaction probe with Large deformation
- Running multiple LS-DYNA simulations with batch files
823
599
591
366
