If the stress is higher than ultimate strength in Response Spectrum Analysis, does this mean that the component may break or yield?
June 6, 2022 at 9:58 am
FAQParticipantResponse spectrum provides the Maximum possible stress that the structure can experience during the entire transient event that is represented by input response spectrum. It is unlikely that all modal maxima will act simultaneously and be of same sign, so in realty stress is probably smaller than predicted in response spectrum, so stress higher than ultimate strength in response spectrum does not necessarily mean the component will fail.
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
