Legacy Products
Legacy Products
Discovery AIM – Fluid-Solid Heat Transfer and Structural Simulation of a Cooling Jacket
    • SolutionSolution
      Participant
      cooling-jacket-fluid-solid-heat-transfer-structural-19-0.zip
      Application example of a cooling jacket simulation with fluid-solid heat transfer and structural coupling. Hot water is passed through the middle of the device and cold water goes through the jacket. The temperature distribution through the steel jacket is calcaluted. The temperatures are then sent to a structural simulation, where the thermally induced stresses are calculated. This project requires release 19.0 or newer.
