May 23, 2024 at 7:26 amkim kyuraeSubscriber
May 29, 2024 at 1:38 pmNilay PedramForum Moderator
What selection method did you use when applying the probe? -
August 5, 2024 at 1:58 pmPetros DiakoumakosAnsys Employee
Can you try using Vertex Average report type rather than Area Average? This will yield more accurate values when you click Compute.
- The topic ‘Why are the coordinates I specified and the coordinates outputted in the report’ is closed to new replies.
Ansys Innovation Space
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- Varying ply angle in ACP
- CONVERTING STL FILE IN TO SOLID
- the matrix T in the cyclic symmetric formula!!
- Element type definition – Ansys Workbench
- Assiging one parameter as thinkness of few shell objects
- ANSYS ACP Modelling Issue
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
591
544
524
366
