October 8, 2024 at 11:49 pmkklngSubscriber
I'm having issues with my ACP model. This is a sandwich composite material. Ideally, this frame should be uniform thickness, however, because of the inner tapers, there is extra thickness. I read that extrusion guides may be able to fix this problem, but I am not sure how to define that extrusion guide. Also, is there a way to add relief cuts? Any help is appreciated, thanks!
October 18, 2024 at 10:26 amAshish KhemkaForum Moderator
I am not an expert but please see if the following link helps you: 5.3. Solution (ansys.com)
Ashish Khemka
Ansys Innovation Space
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- Varying ply angle in ACP
- CONVERTING STL FILE IN TO SOLID
- Element type definition – Ansys Workbench
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- ANSYS ACP Modelling Issue
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
591
569
525
366
