November 2, 2024 at 4:56 pmsametkymkc0Subscriber
I am trying to change the ply angle of the fabrics. But i couldn't find any option for that. For example, i have 0 and 90 fiber orientation of fabric but i want some pitch angle while plies stacking up. Is it possible in ACP if so, how? -
November 8, 2024 at 10:32 amAshish KhemkaForum Moderator
In Ansys Composite PrepPost (ACP), you can change the fabrics' ply angle to introduce a pitch angle while stacking up the plies. The process involves defining the fiber direction and the ply angle, which determines the orientation of the fibers with respect to a reference direction.
To manage the fiber direction and introduce different ply angles, you can utilize the Fabric Fiber Angle property. This property allows you to specify the orientation of the fibers. When the Fabric Fiber Angle property is active and nonzero, you need to specify the material properties with respect to the material directions rather than the fiber directions. This means that you can adjust the ply angle to change the orientation of the fibers in your composite analysis.
Additionally, ACP provides a draping simulation tool that can be used to evaluate the effects of ply draping on doubly curved surfaces, which might change the theoretical fiber orientations. This tool allows you to visualize the draped fiber directions and consider them in your analyses, which could help in ensuring the continuity of the fiber direction across the composite structure.4.5. Shear Dependent Materials in Composite Analysis
Ashish Khemka
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- Varying ply angle in ACP
- CONVERTING STL FILE IN TO SOLID
- Element type definition – Ansys Workbench
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- ANSYS ACP Modelling Issue
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
1311
591
569
525
366
