April 11, 2025 at 8:34 pm
whiteten6
SubscriberHi,Â
I am working on a 2D model using fluent. The issue is that the optimization process is currently not functioning as expected. We identified the root cause: there is a persistent problem within Workbench where, after updating the geometry, the connection between the mesh and Fluent fails, resulting in a crash. Could anyone help us solve this? -
April 15, 2025 at 1:52 pm
HG_17
Ansys EmployeeÂ
Please ensure that all connections are correct and the case is properly set up. Verify that your solution runs successfully, as there might be an issue with its initialization or execution. Additionally, check your software versions and confirm that all files are in the same working directory.
Ansys Innovation Space
- NA
- Response constraint not allowing structural optimization to solve.
- Protected Depth Topology Optimisation
- OptiSlang does not create LsxDefs while importing LS-DYNA output
- Feasibility Check – FT Sensor Flexible Chassis Design Optimization
- Issue with Reaction Force Scaling in ¼ LS-DYNA Model Simulation
- Method to properly export/import APDL readable solids
- OptiSlang sensitivity analysis can’t assign different values to the parameters
- the Ansys workbench optimization
- Extremely Low Rotor Core Loss in Rotor Lamination Simulation Using Maxwell 2D
1036
1005
859
804
