December 9, 2024 at 2:27 pm
f.p.parson
SubscriberHi I am trying to use topology optimization through workbench to optimize a bracket design, I have created seperate bodies through a CAD software to create the exclusion zonesas ansys does not allow you to customize the thickness, but for some reason when I try to input the response constraint it does not allow me to solve the simulation. Also for objective there is no option for compliance constraint.
I would be grateful if you could help with this.
December 10, 2024 at 1:38 pm
December 10, 2024 at 3:39 pm
f.p.parson
SubscriberHi Deepak, the layout of the simulation is all good, I ran it with just using the exclusion zone faces at the location of the fixed supports and it was fine however ansys does not allow you to add thickness to exclusion zones on its software so I added them as seperate CAD bodies. The static structural deformation simulations runs fine but for some reason when I try to run topology optimization the resposone constraint still has a question mark by it.Â
December 10, 2024 at 3:57 pm
Deepak
Ansys EmployeeWhat do you mean by separate CAD bodies? Can you share a rough sketch or model image of the thickness that you are trying to exclude?Â
December 10, 2024 at 4:10 pm
f.p.parson
Subscriber-
December 10, 2024 at 4:43 pm
February 10, 2025 at 7:25 am
helgaella99
SubscriberEnsure all bodies are properly defined, and check if you're using the correct setup for topology optimization. Consider reviewing documentation or forums for specific troubleshooting tips. Incredibox Mustard
April 2, 2025 at 4:37 am
ryrose511
SubscriberEnsure exclusion zones are correctly assigned, use "Minimize Compliance" as the objective, and check that response constraints are valid. Also, review solver logs for errors. brain lines
May 31, 2025 at 7:20 am
- NA
- Response constraint not allowing structural optimization to solve.
- Protected Depth Topology Optimisation
- OptiSlang does not create LsxDefs while importing LS-DYNA output
- Feasibility Check – FT Sensor Flexible Chassis Design Optimization
- Issue with Reaction Force Scaling in ¼ LS-DYNA Model Simulation
- Method to properly export/import APDL readable solids
- OptiSlang sensitivity analysis can’t assign different values to the parameters
- the Ansys workbench optimization
- Extremely Low Rotor Core Loss in Rotor Lamination Simulation Using Maxwell 2D
3286
1036
1005
859
804
