May 19, 2025 at 1:16 pm
carlosaterans
SubscriberI'm running sensitivity analysis in OptiSlang, but I keep getting constant warnings about the assigned values to the parameters:
"Parameter update incorrect: Attempted = 0.0114, Assigned =Â 0.15, Name = Ceramic_Thickness"
such that it is assigning the same objective values to every parameter in every design, so to results are not changing at all. How can I fix this?
May 27, 2025 at 8:06 am
Markus
Ansys EmployeeHi carlosaterans,
in which node of the workflow is the names Parameter "Ceramic_Thickness" used?
Can you provide a screenshot where the assignment is shown, please?Best regards,
Markus
Ansys Innovation Space
- NA
- Response constraint not allowing structural optimization to solve.
- Protected Depth Topology Optimisation
- OptiSlang does not create LsxDefs while importing LS-DYNA output
- Feasibility Check – FT Sensor Flexible Chassis Design Optimization
- Issue with Reaction Force Scaling in ¼ LS-DYNA Model Simulation
- Method to properly export/import APDL readable solids
- OptiSlang sensitivity analysis can’t assign different values to the parameters
- the Ansys workbench optimization
- Extremely Low Rotor Core Loss in Rotor Lamination Simulation Using Maxwell 2D
1036
1005
859
804
