March 18, 2025 at 6:03 pm
pxk247
SubscriberI am trying to perform a topology optimisation simulation on an F1 Rear wing. I have assigned fixed supports with a protected depth to areas with share interfaces with bodies that have been hidden as they are not being optimised. They need to be fixed in order to still maintain contact with the neighbouring surface, in this case the main wing, however although I can see the region which has been assigned as protected (red region) the software has still optimised the area and gotten rid of volume in that area.
March 24, 2025 at 9:18 am
March 24, 2025 at 10:50 am
pxk247
SubscriberHi, yes I am.Â
March 26, 2025 at 9:01 am
Devendra Badgujar
Ansys Innovation Space
- NA
- Response constraint not allowing structural optimization to solve.
- Protected Depth Topology Optimisation
- OptiSlang does not create LsxDefs while importing LS-DYNA output
- Feasibility Check – FT Sensor Flexible Chassis Design Optimization
- Issue with Reaction Force Scaling in ¼ LS-DYNA Model Simulation
- Method to properly export/import APDL readable solids
- OptiSlang sensitivity analysis can’t assign different values to the parameters
- the Ansys workbench optimization
- Extremely Low Rotor Core Loss in Rotor Lamination Simulation Using Maxwell 2D
1036
1005
859
804
