TAGGED: batch-file, hpc-cluster, lsdyna, modules, mpp, version
December 14, 2024 at 1:32 pm
rajesh.pamarthi2711
SubscriberHI,I am trying to perform simulation of my .k file in HPC cluster. My .k file has a total of 240952 elements. And i have following softwares available in my HPC.ansyscleasybuildlibmppdyna_d__avx2_ifort190_intelmpi.solibmppdyna_s__avx2_ifort190_intelmpi.sols-dyna_mpp_d_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018.l2als-dyna_mpp_d_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelibls-dyna_mpp_d_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelib.tgzls-dyna_mpp_s_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018.l2als-dyna_mpp_s_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelibls-dyna_mpp_s_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelib.tgzls-dyna_smp_d_R14_1_0_x64_centos79_ifort190_sse2ls-dyna_smp_d_R14_1_0_x64_centos79_ifort190_sse2.l2als-dyna_smp_d_R14_1_0_x64_centos79_ifort190_sse2.tgzls-dyna_smp_s_R14_1_0_x64_centos79_ifort190_sse2ls-dyna_smp_s_R14_1_0_x64_centos79_ifort190_sse2.l2ampp-dynampp-dyna-dmpp-dyna-ssmp-dynasmp-dyna-dsmp-dyna-sI am trying to submit a sbatch job like in the manner in the command line,#!/bin/bash#SBATCH --time=01:00:00 # walltime#SBATCH --nodes=1 # use 1 node#SBATCH --ntasks=32 # number of processor cores (i.e. tasks)#SBATCH --mem-per-cpu=4000M # memory per CPU core#SBATCH --output=output.log#SBATCH --error=error.logmodule load GCC/13.2.0 OpenMPI/4.1.6 intel-compilers/2023.2.1 impi/2021.10.0 Python/3.11.5 SciPy-bundle/2023.11 matplotlib/3.8.2 LS-DYNA/14.1.0srun mpp-dyna i=/home/pro/main.k memory=120000000but with the above settings with ntasks =32, i have got a status.out file stating it will take 285hrs to complete. Its too long. Can someone help me how to speed up the completion.
Thank you -
December 18, 2024 at 12:38 am
Reno Genest
Ansys EmployeeHello Rajesh,
How many cores did you actually use for your LS-DYNA run? Have a look at the d3hsp or the mes0000 file. If you ran on 32 cores, you should have mes0000 - mes00031 in the working directory. Is it the case?
Your command line to run LS-DYNA is:
The first part should be pointing to the MPI (Intel, Platform, Open, etc.) mpirun executable and then you should have the command "-np" to specify the number of processors to use in your LS-DYNA run. I don't see it in your case. Here is an example of a command line to run MPP LS-DYNA with Platform MPI on Linux:
/data2/rgenest/bin/ibm/platform_mpi/bin/mpirun -np 4 /data2/rgenest/lsdyna/ls-dyna_mpp_d_R13_0_0_x64_centos610_ifort190_sse2_platformmpi/ls-dyna_mpp_d_R13_0_0_x64_centos610_ifort190_sse2_platformmpi i=/data2/rgenest/runs/Test/input.k memory=20m
Have you tried with a command line like above? You will find more LS-DYNA command line examples in the following forum post:
Let me know how it goes.
Reno.
December 18, 2024 at 12:40 am
Reno Genest
Ansys EmployeeHello,
After you make sure you run on 32 cores, you can try to bind processes to cores and see if you can speedup the calculation further. I found the following in our knowledge database:
By default, an MPI process migrates between cores as the OS manages resources and attempts to get the best load balance on the system. But because LS-DYNA is a memory intensive application, such migration can significantly degrade performance since memory access can take longer if the process is moved to a core farther from the memory it is using. To avoid this performance degradation, it is important to bind each MPI process to a core. Each MPI has its own way of binding the processes to cores, and furthermore, threaded MPP (HYBRID) employs a different strategy from pure MPP. I. Pure MPP ============ To bind processes to cores, include the following MPI execution line directives according to the type of MPI used. HP-MPI, Platform MPI, and IBM Platform MPI: -cpu_bind or -cpu_bind=rank -cpu_bind=MAP_CPU:0,1,2,... <<<< not recommended unless user really needs to bind MPI processes to specific cores IBM Platform MPI 9.1.4 and later: -affcycle=numa Intel MPI: -genv I_MPI_PIN_DOMAIN=core Open MPI: --bind-to numa "Let me know how it goes.
Reno.
December 19, 2024 at 10:46 am
rajesh.pamarthi2711
SubscriberHi Reno,
When I executed the job only using -
srun mpp-dyna i=/home/pro/main.k memory=120000000, I can see the mes0000 - mes00031 files in my working directory. I think the SLURM manager automatically allots the ntasks to the lsdyna and its working.
And due to the new comaptitibility issue of modules, I have removed my OPEN MPI module. so currently i am only using -
module load GCC/13.2.0 intel-compilers/2023.2.1 impi/2021.10.0 Python/3.11.5 SciPy-bundle/2023.12 matplotlib/3.8.2 LS-DYNA/14.1.0
with the above modules and with the lsdyna execution command (please look at the mpirun path and lsrun path)
/software/rapids/r24.04/impi/2021.10.0-intel-compilers-2023.2.1/mpi/2021.10.0/bin/mpirun -genv I_MPI_PIN_DOMAIN=core -np 24 ls-dyna_mpp_d_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelib i={new_file_path} memory=200M'
I have run some jobs with options.
1) np32, memory=20m, binding cores disabled - 185 hrs (status.out file)2) np32, memory=20m, binding cores enabled - 168 hrs (status.out file)
3) np32, memory=200m, binding cores enabled - 168 hrs (status.out file)
4) np24, memory=200m, binding cores enabled - 190 hrs (status.out file)
I am using IMPI here as you can see in the loaded modules. and i have given the path to the lsrun executable, can you once look at the path. I have tried many different settings (changing nodes, cores, memory in sbatch, memory option in lsdyna command), but i am not able to optimize. The simulation kinda consists of running the electromagnetic solver execution -
December 19, 2024 at 10:48 am
rajesh.pamarthi2711
SubscriberHi,
And I would like to ask, is setting the memory and memory2 option in the LSDYNA command mandatory? -
December 19, 2024 at 6:16 pm
Reno Genest
Ansys Employee -
December 19, 2024 at 6:19 pm
Reno Genest
The memory= and memory2= are not mandatory, but it can lead to issues if your model is large and not enough memory is requested. Note that memory2= is only used in MPP. You will find more information about memory in the LS-DYNA User Manual Vol I Appendix O: LS-DYNA Keyword Manual
Reno.
December 26, 2024 at 3:28 pm
rajesh.pamarthi2711
SubscriberHi,
I have tried to run the simulation with 3 nodes and 147 tasks. the termination time is about 6.000e-04 (control_termination)#SBATCH –nodes=3 # use 1 node#SBATCH –ntasks=147 # explicitly bind tasks to cores#SBATCH –mem-per-cpu=4000M # memory per CPU core#SBATCH –error=error.logmodule load GCC/13.2.0 intel-compilers/2023.2.1 impi/2021.10.0 Python/3.11.5 SciPy-bundle/2023.12 matplotlib/3.8.2 LS-DYNA/14.1.0python ls.py
with one of the following line in Python code,lsdyna_command = f’/software/rapids/r24.04/impi/2021.10.0-intel-compilers-2023.2.1/mpi/2021.10.0/bin/mpirun -genv I_MPI_PIN_DOMAIN=core -np 147 /software/rapids/r24.04/LS-DYNA/14.1.0-intel-2023b/ls-dyna_mpp_d_R14_1_0_x64_centos79_ifort190_avx2_intelmpi-2018_sharelib i={new_file_path} memory=128M'# Execute the LS-Dyna commandprint(“Running LS-Dyna…”)run_command(lsdyna_command)
For the above, the simulation started execution but appears to be terminated before total completion time. In my d3hsp, it gave out709 t 3.5450E-05 dt 5.00E-08 electromagnetism stepLicense routines forcing premature code termination.Contact with the license server has been lost.The server may have died or a network connectivity problemmay have occurred.710 t 3.5500E-05 dt 1.00E+06 write d3dump01 file 12/24/24 21:37:58710 t 3.5500E-05 dt 1.00E+06 flush i/o buffers 12/24/24 21:37:58710 t 3.5500E-05 dt 1.00E+06 write d3plot file 12/24/24 21:37:59N o r m a l t e r m i n a t i o n 12/24/24 21:37:59S t o r a g e a l l o c a t i o nMemory required to complete solution (memory= 5235K memory2= 2508K)Minimum 2408K on processor 5Maximum 2508K on processor 36Average 2424KMatrix Assembly dynamically allocated memoryMaximum 56MAdditional dynamically allocated memoryMinimum 162M on processor 121Maximum 217M on processor 146Average 170MTotal allocated memoryMinimum 220M on processor 121Maximum 275M on processor 146Average 228MT i m i n g i n f o r m a t i o nCPU(seconds) %CPU Clock(seconds) %Clock—————————————————————-Keyword Processing … 2.8257E+00 0.01 2.8348E+00 0.01MPP Decomposition …. 1.6675E+01 0.06 1.7915E+01 0.06Init Proc ………. 1.0730E+01 0.04 1.0759E+01 0.04Decomposition …… 5.4681E-01 0.00 5.5070E-01 0.00Translation …….. 5.3983E+00 0.02 6.6042E+00 0.02Initialization ……. 1.3516E+01 0.05 1.3698E+01 0.05Init Proc Phase 1 .. 2.6186E+00 0.01 2.6754E+00 0.01Init Proc Phase 2 .. 1.4131E+00 0.01 1.4373E+00 0.01Element processing … 9.0849E-01 0.00 6.1107E+01 0.22Solids …………. 5.8148E-01 0.00 3.8135E+01 0.13E Other ………… 8.5733E-02 0.00 6.8885E+00 0.02Binary databases ….. 2.9037E+01 0.10 4.4529E+01 0.16ASCII database ……. 1.1411E-01 0.00 7.0965E+00 0.03Contact algorithm …. 8.2748E+01 0.30 1.1298E+02 0.40Interf. ID 1 1.9341E+01 0.07 1.9670E+01 0.07Interf. ID 2 5.4628E+01 0.20 7.0596E+01 0.25Rigid Bodies ……… 4.2108E+01 0.15 5.3479E+01 0.19EM solver ………… 2.7242E+04 98.45 2.7758E+04 97.85Misc …………… 6.1301E+02 2.22 6.6360E+02 2.34System Solve ……. 2.5164E+04 90.94 2.5492E+04 89.86FEM matrices setup . 1.1896E+02 0.43 1.3114E+02 0.46BEM matrices setup . 3.5966E+02 1.30 3.8563E+02 1.36FEMSTER to DYNA …. 4.3925E+02 1.59 5.2618E+02 1.85Compute fields ….. 5.4711E+02 1.98 5.5925E+02 1.97Time step size ……. 1.4727E+02 0.53 1.5686E+02 0.55Group force file ….. 1.0339E-02 0.00 8.1230E-01 0.00Others …………… 1.1413E+01 0.04 1.6252E+01 0.06Force Sharing …… 1.1304E+01 0.04 1.3013E+01 0.05Misc. 1 ………….. 4.3898E+00 0.02 2.2644E+01 0.08Scale Masses ……. 7.7710E-03 0.00 5.5401E-01 0.00Force Constraints .. 1.3901E-02 0.00 6.8301E-01 0.00Force to Accel ….. 1.0230E-02 0.00 7.7030E-01 0.00Constraint Sharing . 3.3435E-02 0.00 1.2809E+00 0.00Update RB nodes …. 3.8281E-02 0.00 2.4141E+00 0.01Misc. 2 ………….. 1.1875E-01 0.00 9.0182E+00 0.03Misc. 3 ………….. 7.7356E+01 0.28 8.4258E+01 0.30Misc. 4 ………….. 1.1225E-01 0.00 6.7043E+00 0.02Timestep Init …… 1.6812E-02 0.00 4.6854E-01 0.00Apply Loads …….. 8.1626E-02 0.00 5.6807E+00 0.02—————————————————————-T o t a l s 2.7670E+04 100.00 2.8368E+04 100.00Problem time = 3.5500E-05Problem cycle = 710Total CPU time = 27670 seconds ( 7 hours 41 minutes 10 seconds)CPU time per zone cycle = 161549.932 nanosecondsClock time per zone cycle= 165622.228 nanosecondsParallel execution with 147 MPP procNLQ used/max 64/ 64
I think the totoal termination has not executed, it prematurely stopped execution -
December 26, 2024 at 6:57 pm
Reno Genest
Could you create a new post for this problem? You get the following message:
License routines forcing premature code termination.Contact with the license server has been lost.The server may have died or a network connectivity problemmay have occurred."It looks like you lost communication with the license manager. This is a different problem.In the new post, state the error message and also specify if you are using the LSTC License manager or the Ansys license manager to run LS-DYNA.Reno. -
December 26, 2024 at 7:48 pm
rajesh.pamarthi2711
SubscriberHi Reno,
Apart from the license issue, do you
think any issue with the way lscommand specified in the python? is everything else all right? Its taking many hours to run the model which has 241000 elements.
And in HPC, how to know the which type of license manager is running? -
December 26, 2024 at 8:06 pm
Reno Genest
The command line seems fine; you ran for more than 7 hours on 147 MPP processors.
The EM solver part takes most of the calculation clock % time. Your EM timestep before the license problem was 5e-8 second. This is quite small. Did you specify this timestep using *EM_CONTROL_TIMESTEP? Could you increase the EM timestep to reach your termination time faster? Note that if you have structural parts, the solid mechanics timestep should be smaller or equal to the EM timestep.
Reno.
December 26, 2024 at 8:11 pm
Reno Genest
Also, note the following information from our training on the Ansys Learning Hub (ALH):
So, the memory= command has no effect for the EM part of the model.
EM: Eddy Current Applications (Materials ONLY) – EM: Eddy Current Applications
Have you tried with the latest R15.0.2 MPP solver?
LS-DYNA (user=user) Download Page
Username: user
Password: computer
Reno.
December 26, 2024 at 8:25 pm
rajesh.pamarthi2711
SubscriberHi Reno,
Yes, its specified through EM_CONTROL_TIMESTEP, I cannot increase the EM time step, i have to make it run with that value.
Do you think any other issue, like with the setting env variables or license.
I have parts like inductor, workpiece, field shaper and others , 5 in total . All acounting to section_solid of element 2 form.
control termination - end_time= 6.000e-04
control timestep - TSSFAC =0.667
EM_CONTROL_TIMESTEP = 5.000e-08 -
December 26, 2024 at 8:30 pm
Reno Genest
Please create a new post for the license question. We will help you in the you thread.
Thanks,
Reno.
4613
1530
1386
1209
