3D Design
3D Design
Spaceclaim Parameters
    • Fabian Scr
      Is it possible in SpaceClaim to use the property fields (or custom properties) for parameterization? For example, if the file name is '100', the length of the geometry becomes '100', and so on.
    • NickFL
      Yes I suppose you could, but it seems a little backwards because we usually create the model then save. But in theory you could use SpaceClaim python scripting to do something like this:
      # Python Script, API Version = V23
      import re
      # File Called dummy_100_mm.scdoc
      fileName = DocumentHelper.GetActiveDocument()
      fileName = fileName.Path
      q = re.search(‘_(.+?)_mm’, fileName)
      q = q.group(1)
      print(q)
      You could then use the quantity q in your model.
