September 23, 2024 at 7:59 pmred73mustangSubscriber
Hope this is the right place to ask, but I consistanly get this error in Space Claim when using the thicken tool for the inside of a model
I've tried reapairing but nothing works.
Thanks, Chet
September 24, 2024 at 6:22 amNickFLSubscriber
How “dirty” is the model? When the triangles are fully connected and are not smooth, then adding thickness can result in non-manifold bodies. If the surface you are trying to thicken is smooth, then you may be able to use the skin tool. See below for an example.
https://www.youtube.com/watch?v=k5J260NepRs
September 24, 2024 at 2:38 pmred73mustangSubscriber
I can upload the model but it seams that any file that I try gives the same results (Unless they're all "Dirty" files) I was under the impression that SC can still thicken non-manifold models. Will give the Skin-Tool a look. Thanks.
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
1281
591
544
524
366
