December 15, 2024 at 9:57 ammuhammadagussrihartoSubscriber
Hi guys , I need attention from you all. First of all , It is relate to require RAM for doing analyst CFD in ansys fluent . If I have 24 GB RAM with processor i7 4 core, is it enough for 6M cell and the model is ship with five hull only hull for the model running in cfd fluent . Secondly , Is there any suggestion for me to running cfd for pentamaran ship which doesn't need more than 24 GB RAM ? Lastly , For the information I only find the total resistance for the ship .
Thanks for advance, I using ansys 18.2Â .
December 16, 2024 at 10:15 amRobForum Moderator
You really need to update, R18 is a long way behing the current solver.Â
Depending on models 24GB will allow 6-8M cells, possibly nearer 12-18M with SIMPLE but adding in VOF is likely to push you to the lower end. It also depends on the element types. Modelling more complex shapes will need more cells, so you'll need to see if you can take advantage of symmetry or use a bigger computer.Â
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
1882
802
599
591
366
