December 17, 2024 at 1:15 pmfatmaburcu.soyluSubscriber
Hello everyone,
I have a question about importing geometry from CATIA V6 to SpaceClaim. I need a clean geometry in order to mesh it properly with using watertight geometry workflow. First, I cleaned all small surfaces and gaps in CATIA. Then, I exported the geometry in stp format. When I opened this exported geometry in SpaceClaim, the quality of the surfaces are not good enough. Some of the surfaces have some self-intersections and others have some gaps. These gaps aren't recognized when I use the "Open-face" feature. To fix it, I need to seperate the problematic surface first then I need to sew it again with using "Sew" feature. Also, I need to divide the self-intersected surfaces into many small surfaces. I want to prevent this problems. How can I import or export the geometry with high quality surfaces without applying these steps.
Thank you.Â
December 18, 2024 at 7:32 amKeyur KanadeAnsys Employee
You can read CATIA file in SpaceClaim. You can use option on SpaceClaim reader as shown below in FIle -> SpaceClaim Options panel.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
1191
513
488
225
209
