October 12, 2024 at 6:08 am
October 14, 2024 at 6:45 amSubashni RavichandranForum Moderator
I'm not sure I understand your question correctly, but if you are looking to select half of the body, you will need to split the body using the Split body tool and the section plane.Â
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
