TAGGED: ansys-fluent, ansys-hpc, hpc, hpc-cluster, linux-cluster, path
November 26, 2024 at 7:01 am
rahul_kv
SubscriberI am trying to run fluent job on HPC using SLURM job script, but it is not able to load fluent module.when I check for path in HPC where fluent is installed it is opening in GUI. Now I dont know how to find the correct path of ansys fluent installation in HPC which can be used in SLURM job script.
Can anyone know how to know the path of ansys fluent module in HPC, which I would use in SLURM job script. -
November 26, 2024 at 11:30 am
Forum ModeratorIt should be the same path, but you'll need to discuss your local set up with the cluster Admin team.Â
