April 2, 2024 at 2:13 am
Yoonhoo Kim
SubscriberI changed the solder properties(default -> SAC305)
But when I run the solder fatigue analyze, changed properties were not apply to the result
How can I solve this?
April 5, 2024 at 12:46 pm
Gil Sharon
Ansys EmployeeHello Yonhoo,
There are multiple ways to set the Solder material for a part on a PCB.
The default solder for the whole PCB:
-----PCB name>Right click> Circuit Card Properties>Default solder Type
-----This solder is selected for Random Vibration, Mechanical Shock, Harmonic vibration…ETC
The solder for one part:
-----Edit the part in the parts list>Solder material
-----Changing this field from DEFAULT to any solder will over write the PCB solder selection for that individual part
-----For BGA components, the solder material is greyed out and the Ball Material can be selected. (There is no DEFAULT option for BGAs.)
Only for solder fatigue:
-----There is an override of the DEFAULT solder material
-----This applies only to parts that have DEFAULT solder in the part properties
-----Sherlock applies the Solder Material selected in the dropdown menu to any component in the Parts List that does not already have a Solder Material assigned in its Part Properties. This allows you to change the solder type for the entire circuit card, while also assigning specific solder types to individual parts, depending on how the circuit card is assembled.
-----This does not apply to BGA componentsThe Solder material for each component should appear in the results table after running the analysis.
I hope this helps,
Gil
- The topic ‘How can I apply the edit properties to the analysis results?’ is closed to new replies.
- how to create rays of light passing across a hollow cylinder
- completed the 6 learning track courses but BADAGES are missing
- hole in a cylinder
- Why cylindrical coordinate system is rotated
- Geometry prep for structural simulation using Ansys discovery, Bracket tutorial
- Not able to get my Badge of the learning track
- Inertia Relief Analysis of Fixed Wing Drone
- Intro to Ansys APDL Scripting Course – Solid Meshing Lesson 3
- Innovation Course Stress Analysis in Solid Mechanics
5589
1885
1403
1298
