3D Design
3D Design
Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
    • jacob.lurvey
      Hi All,
      I'm struggling with performing what I think should be a relatively simple task. I have an .STL geometry that I import into SpaceClaim as facets, and I want to keep it that way for eventual import into Fluent Mesher as an .scdoc. It is imported already clipped at both ends, so I know the location of the inlet and outlet. I've attached a picture of the geometry.
      What I want to do is to get all the faces on the inlet and outlet (shown highlighted in orange here) and put them in a named selection. Ideally, I would select all faces with the correct normal vector, but any method that will allow me to automate named selections for the inlet and outlet will work.
       The reason I need to automate this is because I want to process a whole load of similar geometries, all of which have known normals for the inlet and outlet facets. However, since I have to call GetRootPart.Meshes[0] instead of GetRootPart.Bodies[0], lots of the methods in the documentation don't seem to work. Is there any way to do this in SpaceClaim scripting?
      Thanks for any help you can provide
Viewing 0 reply threads
