March 24, 2022 at 3:28 pmsolovievSubscriber
We have previously used profiles to load data into boundaries in Fluent 2020 and previous. Now that we have switched to 2022R1 the profiles are now having name issues. When reading profiles the name goes to '----' (preview not available) for all profiles I load, and therefore the old one is overwritten by any new ones that are read. I checked the 2022 user guide to check if formatting has changed and it hasn't according to the guide the format should be as follows for .csv profiles:
[Name]
name
[Data]
x,y,z,velocity
insert data here....
This is the same format we used previously but now when it is loaded the issue above happens.
Thanks,
Alex
March 24, 2022 at 4:43 pmRobForum ModeratorPlease can you post some screen shots?
March 24, 2022 at 8:26 pmMarch 25, 2022 at 9:47 amAmine Ben Hadj AliAnsys EmployeeI cannot reproduce the issue with the name in 22R1.
I copied the example from the documentation and put it in a file. Can you try that?
March 25, 2022 at 3:30 pmRobForum ModeratorThe example is comma delimited, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_ug/flu_ug_sec_bcprof_format.html can you check you've not conflated two profile syntax styles? I assume you've not pushed the text straight to Linux without doing "dos2unix" on the Linux side?
March 25, 2022 at 7:45 pmsolovievSubscriberThank you Rob and DrAmine. I found that when you specified comma delimited that there were extra commas when the profile was loaded in a text editor as compared to excel, which didn't show these extra commas. When they were removed the name was read in correctly.
Thanks Alex
March 28, 2022 at 2:20 pmRobForum ModeratorMicrosoft 1, User 0. :) Thanks for letting us know.
Viewing 6 reply threads- The topic ‘Fluent profile reading name issue 2022R1’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Non-Intersected faces found for matching interface periodic-walls
- Cyclone (Stairmand) simulation using RSM
- error udf
- Diesel with Ammonia/Hydrogen blend combustion
- Fluent fails with Intel MPI protocol on 2 nodes
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script error Code: 800a000d
- Encountering Error in Heterogeneous Surface Reaction
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
