EXPLICIT ANALYSIS
    • Vishwajeet Kashyap
      Is there any possible point to get the output parameters A3 and B6 cell in parameters set ?
      Note: Provide the input parameters remains same.
    • Nanda Veralla
      Hello Vishwajeet,
      Could you provide more details on your workflow. Did you post any screenshot? There might be an error in uploading, we are not able to see any screenshot. What is the analysis type of system A and B?
      Nanda.
    • Nanda Veralla
      Hello Vishwajeet,
      Can we get more details, your intial statement looks incomplete. Are you referring to "changing an output parameter to input parameter"? If this is what you're referring to, this link might be of help to you:
      Chaining an Output Parameter to an Input Parameter (ansys.com)
      Also, refer to this Ansys help links for more details on using parameters:
      Working with Parameters (ansys.com)
      Setting Parameters (ansys.com)
      If this is not what you're trying to accomplish, please provide us with more details on your application. It will help forum member's to better understand the challenges you're facing.
      Thanks,
      Nanda
    • Nanda Veralla
      Hello Vishwa,
      I just bumped into your other forum discussion here:
      Explicit dynamic (ansys.com)
      Did you try Lydia's suggestions? What is the end goal of your application? Do you want to use the deformed geometry of system A as the base model for system B? Can we know more about the objects/things you're trying to parameterize?
      Thanks,
      Nanda
Viewing 4 reply threads
  • The topic ‘EXPLICIT ANALYSIS’ is closed to new replies.
