February 28, 2024 at 6:35 pmMiguel SanchezSubscriber
I´d like to perform a parameterized optimization study using the thickness of a sheetmetal part as parameter. I know how to edit the thickness in the properties tab but cannot find out how to make it a parameter to be used in workbench/mechanical afterwards.
I found this hint here, but it does not seem to work under the sheetmetal tab...
Any other idea or suggestion? Thanks.
February 29, 2024 at 9:11 amDevendra BadgujarForum Moderator
Hello Miguel,Â
Let me check and get back to you on this.
Devendra
February 29, 2024 at 12:19 pmMiguel SanchezSubscriber
Thanks Devendra!
I am trying to compare results for various sheetmetal parts designs with different thicknesses and features (bends, beam-ribs, gussets,…) so any other suggestion/hint (e.g. better use solid-bodies or surface-bodies extracting mid-surfaces from solids? how to account for the sheet (planar and normal) anisotropy?, etc.) will be welcome!
Regards
March 5, 2024 at 6:13 pmMiguel SanchezSubscriber
Hi Devendra,
No news about this topic? I´ll appreciate it since I am stuck.
Thanks
March 15, 2024 at 12:23 pmDevendra BadgujarForum Moderator
Hello Miguel,Â
Its not possible to parametrize the thickness of the Sheet metal from the options shown below in the properties panel:
You can refer the Using a Bend Deduction Table where you define combination of Thickness and VeeDieWidth like one shown below:
Although this is for bend radius and not directly for thickness. Comma-Separated Value FileÂ
Another way could be to create a mid-surface and assign a thickness to it in Mechanical. Let me know if this helps.
Thanks,Â
Devendra
March 16, 2024 at 9:02 amMiguel SanchezSubscriber
Thanks Devendra!
That´s fine. It´s pretty much the same recommendation I got from your mate Sampat Kumat here:
/forum/forums/topic/sheet-metal-parts-in-spaceclaim-and-mechanical/#post-357248
What about the questions about how to deal with other sheetmetal parts features (bends, beams/ribs/dimples, gussets,…) and characteristics (planar and normal anisotropy, springback, eventual thinnings,...)? Any tips there?
Thanks again.
March 19, 2024 at 2:29 pmDevendra BadgujarForum Moderator
Hello Miguel,Â
Other Sheetmetal features cannot be parametrized. Those are features for modification and creation of sheetmetal parts.Â
DevendraÂ
- The topic ‘create parameter for thickness in spaceclaim sheetmetal’ is closed to new replies.
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
1191
513
488
225
209
