3D Design
3D Design
Cant find layout sketch option in 2025 R2
    • trolldcrafter
      Trying to do a basic truss in 2D but i cant find the setting to not convert my lines to a surface.
      Trying to follow this tutorial (see time 1:32):
      ?t=89
    • Devendra Badgujar
      Try turning this option ON:
      Devendra
    • Govindan Nagappan
      Turn on “Layout sketch” when you are in sketching:
      Or do not go to 3D model from sketching. After creating the sketch, go to Prepare and assign cross section.
      Or Use this workaround: If surfaces are created, you can select the lines and copy/paste it. Then assign the cross section to the lines and delete the surface
