3D Design
3D Design
BUG 2025 Ansys SpaceClaim
    • Tim Dukes
      Hi Support,
      Reporting a few bug with Diameters in the 2025 versions of SpaceClaim. When you add a dimension to a cylinder as below and then click the face in the pull tool and click the white star to edit the value is automatically doubled. If you then click in white space this auto confirms that value. Hopefuly you can see in the image the radius is 45 the value should say 90 once you click on the white star but it doubles.
      Also another geometry bug is the top cylinder in the image below cannot be made larger than the bottom cylinder.
      Thank you
Viewing 0 reply threads
