December 18, 2024 at 10:48 amAntonio Gutiérrez GonzálezSubscriber
I want to evaluate the stress and temperature distribution in an assembly where there are several elements. The boundary conditions are structural support and the temperature of one of the bodies, as can be seen in the example image.
Once I enter the temperature input in one of the bodies, the thermometer appears in each of the materials ("Assembled temperature"). What does this refer to? Does it have any influence?
Best,
Antonio
December 19, 2024 at 8:22 amCharudatta BandgarForum Moderator
Hey Antonio,
Yes the temperature next to the material signifies the initial temperature of the body unless an applied load.Â
Charudatta B
Ansys Innovation Space
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- Crash by using Script Editor
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Temperature’s Distribution not available in Refine Mode ?
- Thermoelectric Cooler Model
513
488
225
209
