March 8, 2022 at 11:19 am
MadScientist
SubscriberMy client side is a computer running Windows and Server side is running Ubuntu 18 (I know, it's not supported, but I had got RSM to work some time back). I have installed the RSM and ARC daemon on the server side.
Now, when I go to validate the credentials from my side, I get the following error.
March 10, 2022 at 9:26 pmMangeshANSYS
Ansys EmployeeHello
please search RSM documentation for
Configuring RSM to Use SSH for Job Submission and/or File Transfers to a Remote Linux Cluster
and try following the detailed steps for the ssh method for communicating with Linux machine
March 17, 2022 at 12:12 pmMarch 20, 2022 at 7:56 pmMangeshANSYS
Ansys Employeetry setting the variable in 4.6.3.1 at https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v221/en/wb_rsm/install_clus_services_linux.html then restart services
March 30, 2022 at 7:28 amMadScientist
SubscriberWhich variable should I set exactly? The arc_env_profile is a file with all lines commented out. I also checked out Ans.Rsm.AppSettings.config file, but it is too large and I don't know what to check there.
May 14, 2022 at 5:58 amMadScientist
SubscriberI was able to resolve the issue without using the SSH method. I had to create another user in Ubuntu, and then give the credentials of that user on the client side, in RSM configuration.
Viewing 5 reply threads- The topic ‘ANSYS RSM Error when connecting from Windows to Linux’ is closed to new replies.
