Ansys Products
Ansys Products
License installation issue
    • mmahamid
      I installed a new license but for some reason according to the instructions, but I can't get it to work. I tried everything with one of the tech support but it is not working, I reread the file and it tells me it is identical, I would greatly appreciate if I can connect with one tech support via teams or zoom to guide me thru what to do.
      Many thanks,
      Mustafa
    • George Karnos
      Hello Mustafa,
      What is the error you are receiving when trying to run the program?
      If licensing related, check the following:
      under %TEMP%\.ansys
      You will see license debug files
      Check the files using notepad for any errors.
