Exploring Design Variations
Want to explore more designs? This part is for you! In this video you will explore how Ansys Discovery lets us quickly analyze and compare multiple designs. The analysis of multiple design variations is a fundamental part of the design process. Every real-world scenario has a specific set of constraints which an engineer uses to determine the optimal choice for a specific application. In this case you will analyze how the height of the heat sink fins affects the temperature of the components.
