Thermal Analysis of the Design
Now that the geometry is ready for the simulation, we can perform the thermal analysis. Here, you will learn how to set up the model to run a solid thermal simulation, which involves defining materials and their thermal conditions. Then, you will explore how to visualize the results to better understand how a heat sink can reduce the temperature of CPUs.
