High-Fidelity Thermal Analysis
Now we are going to set up and run a high-fidelity simulation. Once the best design is chosen, the high-fidelity simulation will provide more accurate results that let us verify how the design will perform. In this video you will explore the details of the Refine stage in Ansys Discovery. You will learn what a computational mesh is and how it affects the solution.
