Fluid Dynamic Analysis of the Design
Once the geometry is ready for the simulation, we can configure the model and perform the analysis. Here you will learn how to run a fluid dynamics simulation, which involves defining the conditions that control how the air will move inside the volume being analyzed. Then, you will explore how to visualize the results and understand how the air blown into the PCB housing by the fans will interact with the various components.
