Exploring a Design Variation
So far, we have learned how to set up a simulation and have explored the expected behavior of the air inside the fluid volume. This allows us to make some inferences about how the moving air affects the heat transfer and temperatures of the different components. This information can be used to modify the design and try to improve it. You will learn how to move the PCB components so that the fluid volume updates automatically. Then, you will analyze the results for this new design.
