The last step of this exercise is to perform the high-fidelity simulation and analyze the results. You will learn how to generate the mesh and control its size. You will also explore how this simulation captures the physics involved in this model while navigating through the final results.
Now that you have completed this course, feel free to try out different designs, apply what you have learned and test your skills.
