Why does the solution diverge for a 2D axisymmetric Mooney-Rivlin rubber model with a centered hole, which is being enlarged by a block that is displaced radially outward? A hole in the middle of a 2D axisymmetric Mooney-Rivlin rubber model is enlarged by a block that is displaced radially outward. Surface to surface contact is defined between the block and the hole. The solution fails to converge due to an element formulation error. Can you suggest anything that would help?
April 13, 2023 at 7:33 amSolutionParticipant
Please refer to the attachment(s) to access the Solution.
1. 345193.pdf
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- Guidelines of modeling a gasket.
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- ANSYS ACCS: Simulation of a Composite Rib Using ANSYS Composite Cure Simulation Tool
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- Hyperelastic Simulations
