Why does a hyperelastic model converge with a 3-D representation, but always fails in 2-D with an element formulation error?
March 17, 2023 at 9:00 am
FAQParticipantAssuming the mesh, loads and BCs are correctly defined, it is possible that the 2-D plane stress or plane strain assumption is invalid for the application, creating an overconstrained condition. This can be the case if it has a finite depth, is under a large compressive load and is a highly compressible foam material.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- Why is the unit of the elastic foundation stiffness N/m^3?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
