General
General
Why am I unable to define a fluid solid interface in a 2D analysis?
    • FAQFAQ
      Participant
      The system coupling involving Mechanical is currently not supported for 2D meshes which is why the ‘fluid solid interface’ option is unavailable. Instead the user is recommended to use a 3D mesh with either linear or cyclic symmetry to perform such simulations.
