When I try to run a solution on RSM, the solver performs the “presolver setup” then throws an error “general failure occurred during the solution process”.
Tagged: 18.2, General, structural-mechanics, workbench platform
April 5, 2023 at 2:32 pm
FAQParticipantThis could be due to ARC master/node not installed. Use following solution. 1. Rename %appdata%ANSYS Incv182ARC to ARC.old 2. Or rename entire %appdata%ANSYS Incv182 folder to v182.old 3. Now launch the WB project
