What is the difference between isotropic hardening plastic model and kinematic hardening plastic model?
Tagged: 19.2, materials, mechanical, Nonlinear mechanics, plasticity, structural-mechanics
January 25, 2023 at 7:34 am
FAQ
Participant1. For monotonically loading, i.e., load goes from zero to some value above the yield point and stops, isotropic hardening and kinematic hardening give the same result, but isotropic hardening is mathematically easier to implement. 2. For cyclic loading, kinematic hardening should be used and isotropic is NOT recommended. 2.1. For small strain (typically 5-10% true strain), linear (bilinear or multilinear) kinematic hardening may be used. 2.2. For large strain, nonlinear (Chaboche) kinematic hardening should be used.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- How do I move a material property from Engineering Data to an existing Material Library?
- Hyperelastic Simulations
