What is the cause of following error message: *** ERROR *** SUPPRESSED MESSAGE CP = 18.814 TIME= 17:05:07 Unable to calculate Residual for 1:crshar .
Tagged: 19, mapdl, materials, mechanical-apdl, Special Purpose, structural-mechanics
April 5, 2023 at 2:33 pm
FAQParticipantFor creep curve fitting in MAPDL, If one has a creep model which requires time (e.g., time hardening model), but do not actually want to include time, even then it will be required to specify a positive value for time in the input file or else an error will result: /temp,1650 /1,seqv /2,dcreq /3,time 1401.81E-021.00 2102.72E-021.00 2804.54E-021.00 3466.48E-021.00 4158.29E-021.00 time is set equal to 1, then fix the constant related to time to zero and perform the curve fit.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- How do I move a material property from Engineering Data to an existing Material Library?
- Why is the unit of the elastic foundation stiffness N/m^3?
- In the Mechanical Fatigue Tool, what is the calculated safety factor?
- Hyperelastic Simulations
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
