What are the considerations for modeling thermo-viscoelastic mechanical behavior of amorphous polymers?
June 5, 2023 at 7:05 amFAQParticipant
The amorphous polymers are known to have a hard, brittle behavior below the glass transition temperature and this behavior changes to a compliant, rubbery behavior beyond the glass transition temperature. Due to this, it is generally recommended to use the thermo-viscoelasitc models in the ranges of temperature that does not include the glass transition temperature. However, there is no mathematical limitations in the WLF or the TN shift functions. A better way to go about this is to obtain the data and develop the viscoelastic master curve. Then plot the shift function over the range of interest and see if you can fit the WLF or TN function to the experimental shift function. If you can’t fit the shift function with a built in model, a user shift function or user material will be required.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- Guidelines of modeling a gasket.
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- ANSYS ACCS: Simulation of a Composite Rib Using ANSYS Composite Cure Simulation Tool
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- Hyperelastic Simulations
