Is there any rational explanation to MISO convergence failure even though stress state is well below the last data point on the stress vs plastic strain curve and BISO solves with no trouble?
Tagged: 2019 R3, materials, mechanical, plasticity, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantSome key points: 1.Unlike the BISO model, MISO does not calculate or use a tangent modulus property directly in the derivation of stress and strain. 2.Increase in force combined with the reduction in cross-sectional area can exceed the slope of the multi-linear hardening curve. 3. From there stiffness decrease without bound (i.e. necking) might occur.
- Question: What is the difference between PLNSOL, EPPL, EQV and PLNSOL,NL,EPEQ?
- How to use layered section to simulate composites and post process the results in ANSYS Mechanical
- Guidelines of modeling a gasket.
- ANSYS Mechanical: Delamination Analysis using Contact Debonding
- For the stress-life fatigue method, how are the Goodman and Gerber mean stress theories used to modify the calculated stress amplitude in the Workbench Fatigue Module?
- Why is the unit of the elastic foundation stiffness N/m^3?
- What are Isochronous stress-strain curves? How can they be used in ANSYS for modeling creep?
- How do I enter major Poisson’s ratio in ANSYS Mechanical?
- ANSYS ACCS: Simulation of a Composite Rib Using ANSYS Composite Cure Simulation Tool
- Hyperelastic Simulations
