March 17, 2023 at 8:59 am
FAQParticipantWorkbench additive does not use laser power. We assume that the process parameters have been set correctly so that all the powder on the top layer has been melted, and not underheated nor overheated. We also heat (melt) the entire layer at once. However, we can indirectly calculate the laser power. Once we have the volume of the melted material, that will give us the mass of it and based on the latent heat(Lf) and heat capacity(C) one can find how much energy is needed for it. Now just divide this energy by the time it took to create that much of molten material, and this will give us the power of the laser. No FEA needed. Q=Power*time=mCΔT+mLf
