In Explicit Dynamics and Autodyn Component systems, do we have to use failure model in the materials that are only used in the multi-material Euler solver when conducting hyper-velocity impact and penetration simulations?
Tagged: 17, Explicit - AUTODYN, mechanical, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantThe answer is no. The multi-material Euler solver usually under-predicts the penetration depth when comparing with experimental results. Using the Euler solver without a material failure model makes numerical results stiffer and thus more close to the experimental measurements. Failure models are still recommended to the materials in Lagrange solver in these simulations
