In a Mode superposition transient analysis, why doesn’t Mechanical show deformation results when Outres,nsol command inserted through command object ?
June 5, 2023 at 7:04 am
FAQParticipantCommand Object: outres,erase outres,all,none outres,nsol,all,nnew1 The OUTRES,NSOL causes the result file to get ready for U, V, and A data.However, since OUTRES,V and OUTRES,A were not included in the snippet, the solver wrote no V and A data. The Mechanical reader has a safety check: the reader feels that V and A data should be on the file.If the reader sees no V and A data, it concludes that the nodal degree of freedom solution is unsafe. This as a limitation of Mechanical, not a defect.Set “calculate Velocity and acceleration” to “No” in Analysis settings. Or add these commands too to the command object: outres,v ,all,nnew1 outres,a ,all,nnew1
- How to setup Initial, Minimum and Maximum time step in Transient analysis?
- In a random vibration analysis, what is “GRMS” and how can it be calculated?
- In Workbench Mechanical, how can I obtain strain energy output for Modal analysis?
- How to define variable thickness shell elements in ANSYS Mechanical? Is there any verification example of the variable thickness shell modal analysis available?
- How to apply application-based settings to improve the performance and robustness of transient structural analyses?
- In the results of a modal analysis, how can I define that a frequency is an output parameter ?
- How to include effect of bolt pretension in a modal analysis?
- How to resolve the “General solver failure” error while running a rigid body dynamics analysis?
- Tips about Postprocessing options for Harmonic Solution in Mechanical
- ANSYS Explicit Dynamics: Using Joints, Joint Loads and Probes
